Plugins 3.5r3
wheres the plugins? when i open zbrush i dont see the plugins, no zapplink 3.5r3, no paintstop. i use win7 so, if someone have solved this problem too…
i put the plugins ( zdata\zplugs)
thanks
You should NEVER modify the contents of your ZData folder. Plugins are to be installed in the ZStartup\Zplugs folder. However, 3.5R3 does not require that you download any plugins. They’re included automatically with a default installation. The only way you would not have gotten them would be if you chose a Custom installation and then deselected the plugins.
If you have 3.5 or 3.5R2 then there are no plugins. You would need to update to R3.
At this point your best option for fixing the issues caused by modifying the ZData folder is to deactivate ZBrush and then uninstall it and delete its folder. Then install it again.
