Hi there,
I am sculpting something in HD Geometry, but when I try to save the tool, it seems that it only saves the current HD region in which I sculpted in HD. (If I exit the HD mode all HD information is gone, and if I save in HD, then it only saves the last region I worked on in HD).
To make myself clearer: it saves the Geometry, but not the applied texture (polypaint).
This is a huge problem, because I work for many hours on one tool and since Zbrush 7 crashes quite often, I would need to save the information I sculpted on (and reload the tool if necessary).
Is there any way to save the complete HD information on one tool, even when you painted on multiple HD regions?
Thank you so much for any help! :o
All the best, Eva Maria
