ok guys i got zbrush but when I start the application my window always appears on the side. can someone help me
Please see the ZBrush 3.5 Tips and Tricks section of the online documentation. (Linked to in my signature.)
I’m having the same problem as above and have tried all three methods of moving the window but none work. I can’t move the window by grabbing the title bar or i’d have no issues. I’m using Windows 7 ultimate 32bit right now, but i’ll be switching to 64bit soon. Any other ways to fix this problem, right now the program is useless to me, all the right side menues are cut off the screen.
screen resolution 1400x900
thanks
If you are unable to drag the ZBrush title bar, this would not be due to ZBrush. Something unusual is happening with your system that is blocking that functionality.
The only think I could recommend trying at this point would be to uninstall ZBrush, delete its folder, then reinstall again.
"trouble moving main ZBrush window
thanks"
Don’t know how but it’s working now tried restarting the computer and everything is good.
Thanks for the quick response Aurick
