Planes in Zbrush
Can I view the model in Zbrush “2 sided materialized” I drew a plane in 3d max applied a displace modifier to make some landscape then convert it in poly mesh export it to Zbrush and here is the result I tried fliping the faces but no use …plz help
I tried everysingle way to go around this process but could nt do it right :cry:
…you must read the Zb pipeline ZB <–> 3DMAx here :wink:
Have happy Zbrushing :wink: :cool:
I read the Pipline before and read again but could nt find what I am looking for but thanks for your attention …
If you want to view the model with the polygons being rendered double-sided, simply turn on Tool>Display Properties>Double.
The problem solved thank you very much aurick
