Hey friends!
Im always using the PINCH brush a lot in early versions of Zbrush, in conjunction with brush modifier seted in 100%. The brush does the pinch , as expected, but with brush modifier in 100% he is not doing anymore the pull (or push, depending if the brush is ser to Add ou Sub) the mesh . This helps aton working in meshs with Lowpoly count because in can achieve a certain “definition” with edges without need to subdivide the mesh ! Great for early stages .
But this is not working like before. The brush is not more pushing or pulling the mesh together with the pinching when we set the brush modifier to 100% in ZBRUSH 2021.
Anyone knows how to fix it?
Thanks in advance
, but no.
