picture maps
Is it possible to create these kind of maps with ZBrusk ?
:qu:
que formato es? de donde proviene este Map?..more info :confused:
its UV Map?
If you mean texture a uv template…absolutely!!!
You can do it either in PM on the 3d object itself or you can load the uvtemplate into texture menu and fill the canvas(best if canvas is same size as uv template) and color and sculpt away in 2.5d.
Is it possible to create something like that ( I don’t know the name ) :
Hey ab,
Yes, it’s possible… It can be done inside Zbrush or you can go to uvmapper.com and download the classic demo to make the map. It will be basis of any texture you decide to create. Go to Solstice Sean Connery thread and check it out. I gave Sol a quick run through on how to use it.
Tartan :slight_smile:
…manipulations :rolleyes:
Just paint your 3D model with Projection Master in Zbrush :smiley:
Pilou
Frenchy,
As far as complex manipulations I guess I am old school on textures. I am so used to using it I dont think of it as complex at all. There are many advantages to using uv mapper (Pro is awesome) one of which is the ability to completely rearrange the map to Your satisfaction. Ie, there might be detail you want in an area. Just take that section of the map and resize it to where you feel the detail will take. You can a lot of things with it. At the moment I am learning projection master at least the basics. i am not sure though that Projection master has the ability to do what i described referring to UV mapper. I will find out though :slight_smile:
Tartan
Is UVMapper the best software ?
I think yes !
Andreseloy
im not expert
IMHO BodyPaint3D R2 is superior. But so is the price (10 times higher…)
LN
…effectly you are some classic :wink:
Pilou
