Hi there
is there a chance to pick a color in Zbrush from an image, opened in preview or PS? I tried to place the same image in the Zbrush background, but then I will run in a lot of trouble with the object. First I had to move it closer to the Cam, because otherwise it sticks into the image. For that I had to use the transposemaster, because I am working with a lot of high detailed subtools and Zbrush tends to crash in this process. AND by moving the obj closer to Cam, I altered the overall pivotpoint. If I now rotate the object in the canvas, at 180° the object disappear behind the image.
I just need this process for texturing.
Is there a better way?
Thanks in advance.
Yours Hilmar
