Photoshop PSD -> ZBrush "Error ^0"
I Get “Error ^0” when I’m trying to import a CS2 texture into Zbrush2 (yeah it’s older).
I was able to do it for the last few days, but now all of a sudden it won’t work.
It will load a much older version of the texture I’m painting, but that doesn’t really help since the texture has dramatically changed since then.
Has anyone seen this problem? (a search for this problem has not revealeda nything).
No, this is not something that I’ve ever seen. However, if it was working fine and now you’re suddenly getting a problem then you’re already on the way to finding a solution.
Take some time to think about what has changed on your system since the time that it last worked. Did you update any software or drivers? Change any system settings? Install any new apps?
For that matter, have you considered running a virus scan?
I did some snooping, and oddly enough found the problem. If I save it with alpha channels, it will give me this error.
otherwise, it’s fine. however, i don’t ever recall having to do this so I don’t know what could have done this…
cheers!
