Perspective: Keyshot Bridge and ZBrush
Ok, I have questions!
Namely, about ZBrush to Keyshot Bridge (beloved btw) and the different perspectives for rendering.
What are good settings for proper perspectives? Retaining Zbrush’s default (50) and applying that to Keyshot?
I will lay out what I know so far:
  • For portraits or bust, Zbrush set to 30 - 45, most other larger objects at 45 - 50
  • 30 for Zbrush is about equal (heh) to Maya’s perspective
  • Some have said set Keyshot’s perspective to 85 to match Zbrush’s 50
  • Its fairly relative to what you are making
  • Keyshot’s 35 default perspective give undesirable results in many cases with portraits / bust
What are the setting you all use?
I figured this out, its relative to what you are Keyshoting, its scale, and the distance and mood you desire.
