Perspective issue
I was wondering if there is any way to increase the depth of perspective in Zbrush.
In the front view image the lamps appear to be a lot closer to each other than I want them to be, but if you look at the side view, the distance is pretty big.
Is there any way to adjust this or do I just have to push them even further back?
cheers.
You can adjust the strength of the Perspective effect using the Angle of View slider in the Draw palette.
Actually I have noticed the same issue and tried the Angle of View slider in the Draw palette.
with no change in the issue.
more noticable when things are the same size and the object furthest away can look twice the size.
