Permanently Visible Hotkeys?
After you open the brush palette and press a key to filter the brushes, the next letter you must press to select them is suddenly displayed on the corner of each brush icon.
Is there a way to permanently display hotkeys in this manner, for example: on the commonly used brushes I docked in my custom UI, so I dont have to hover over them to display the necessary hotkey?
Use a macro button with the text you want displayed.
Ah no, my problem isnt that. I already assigned my own hotkeys for common brushes from keys 1 to 7 or such, which helps me avoid macros completely. The deal is: sometimes I forget if my DamStandard brush was key 5 or 6, for example.
So you see, even with macros, the problem is the same, which macro was for which brush? I forget
I’d really preffer Not to use Post-its next to my keyboard or something of the sorts to remind me, so I was hoping I could display the hotkeys for the brushes I docked Not for easy access, but as a remider/indicator of what hotkey I assigned to them in the first place.
Hope I made sense this time :slight_smile:
Would be a nice feature, don’t you think?
You stated you had brush icon buttons. Text button with your hotkey in the file name :wink:
I’m so sad that’s the only way
You can clone the brushes you use (as a safety precaution) and make your own icons for them as below.
Thanks guys, I guess that’s my only option for now. Hopefully will be a feature someday so it can update whenever you change the hotkey.
