hey all-
hopefully there’s a quick fix that i’m just not seeing…
for my copy of zbrush to run smoothly, i need the max threads count in the preferences to be at 6.
whenever i start zbrush, it’s at 8 and i have to change it manually.
i tried to make the change and save it with my custom UI, but it doesn’t stick.
it doesn’t stick when i try to save it with a startup document or a project file. what am i missing?
also- it’d be nice if certain things would load with the startup document that i have to change manual every time, too:
floor elevation, perspective view angle, light placement and a smattering of rendering settings.
i thought as a workaround, i’d do a primarily blank project file with all those things changed and load it when i start up zbrush.
this works (with the exception of the max threads setting of course)… but it’d be nice if it would load that project file by default, whenever i start zbrush. is there a script, macro, plug-in or magic sauce that will allow a specified project file to be loaded by default when you open zbrush?
as always- thanks a lot for any input!
