Perfect Lines?
I’m trying to figure out how to make perfect lines when using the brush I tried holding shift and the lines I draw are still off center. I like this program but it is so frustrating when coming from years of 3Ds Max and other software that lets you change the numbers when u make a mistake. By lines I mean strokes btw, any suggestions?
If you want to draw straight lines, in the stroke menu you can set Lazymouse, then Backtrack. You can then set the backtrack to line or path and ‘Snap to Track’.
