Is it possible to use Paintstop directly on a 3d model in zBrush? I suppose I could just use paintstop over a uvSnapshot, but it would be great to use the brush tools within zBrush.
thanks
Jon
thanks
Jon
No you can’t. All the brushes in PaintStop are versions of the 2.5D brushes available in ZBrush which only work on 3D models through using Projection Master. If you want to use PaintStop’s features you’ll need to do as you suggest and paint directly on a texture map.
