Painting or Masking goes through to the other side!?
I probably have a very easy to fix problem…
When I paint a relatively thin object or when I try to mask an area on it, the paint or mask goes through to the other side…
I wonder how can I avoid that?
Thanks :slight_smile:
This forum has a very good search feature.
http://www.zbrushcentral.com/zbc/showthread.php?t=70620
I did search… and I did eventually hide half of the object, but I was wondering if there’s a way to disable it and an answer to that I couldn’t find :confused:
I found out how to do it…
In the Brush pallete there’s an option called “BackFaceMask”,
turning that on makes the brush 2D instead of 3D and it’s impossible to paint or mask on both sides, doesn’t matter how thin the object is.
Thanks for still giving the answer
it helped a lot :smiley:
np :wink:
