How can I get Zoom to 1:1 Pixel in Paint Stop ?
I found the button AltDoc.
Is this a RealPixelSize View?
And when, is this the only way?
The ‘Actual Size’ button on the right of the UI generally does it. However, accuracy may depend on your monitor settings. For the best result set the dpi in Edit>Image Resolution to whatever your monitor uses. Generally this will be 96, sometimes 72. Then press the ‘Print’ button on the right.
Hope this helps,
The Alt Doc view shows a scaled view (all the canvas, if you’ve set that in Edit>Preferences and there’s room).
wow thanks!
