You are funny lemonnado :lol:
I will never forget this gret adivce.
Imagine: As a great man once said:
[color=Black]“Take 2 Pixol daily”
This is interesting; Photoshop Extended announced with 3D capabilities.
http://www.adobe.com/products/photoshop/ps_psext_info.html
Incredible system of Bolean operations! :eek:
This release is focused on Booleans.
Booleans between surfaces and solids now work well - previously a boolean between a solid and a surface could create a sort of messed up object.
New “auto-extrude” allows for difference and intersection booleans between a solid/surface and a planar curve or a line. So for example draw a circle and use boolean difference to cut a cylindrical hole through a solid by using the circle as the object to subtract. MoI handles the extrusion of the circle for you automatically. Or another example is draw a sphere, and then draw a line flat on a plane that appears to cut the sphere in 2. Now you can boolean difference the sphere with the line to split the sphere into 2 solid chunks - this is different than using trim since the results are 2 solids instead of a surface like Trim generates.
New curve/curve booleans. You can now use boolean operations on a curve to curve level - this is applied if you select only all curves that are on the same plane when using the boolean commands. Closed curves form regions which can include holes for nested closed curves. Closed regions boolean against closed regions in the same way that solids boolean against solids. Closed curves and open curves can interact in a variety of ways - for instance you can difference a circle with some lines that go through it to cut the circle into smaller closed loops. You can model hatch-type patterns by intersecting a grid layout of open curves against a closed loop. Union will work to find a common closed region or regions to a set of overlapping open curves or lines.
New boolean merge operator - there is a new “merge” operation available which is activated when you select objects, run boolean intersection, but push “Done” without selecting anything for the second intersection set. This can be used to find a common volume to a set of surfaces where some of the surfaces are sticking through each other. It will also generate all combinations of volumes between 2 intersecting solids.
Updated Escape key handling - Escape will still cancel the currently running command as before, but now it can also be used to deselect all objects and turn off points if pushed repeatedly.
A couple other bug fixes.
:o Amazing :o
Mr George B (1815-1864) has found some amazing functions
(special adaption in Moi)
I have been recently playing around with puppets and learning how to do stop motion. I am using a webcam. I recently downloaded Adobe Lightroom and found it great for touching up image sequences. It is very quick!
Here is a Small sample…
http://cccharron.50webs.com/animations/first_test4.html
Has anyone else tried Lightroom?
There goes some more of my fishing money. When will it stop :eek:
Cool!
Modo 203 is out. A free update to registered users.
It also includes a lot of new functionality.
I’m surprised!
Lemo
Thats very true, ive Got TrueSpace6.6,MAX8,Milkshape3D,and just bought Zbrush…trying to learn them all…making models for games and such atm. I do like max 8 even though it was a ton of cash…
Milkshape 3D???
It is the first 3D software I learnt
and I know it by heart
Amazing
I thought Milkshape is dead
my mail adress is “dani_milkshape3duser…”
AMAZING…
Keep walking…
Yeah they just made a new version…it works great now…only using it because they changed it now so we can have more polys,plug-ins are still being made,and I have to convert models into non-existant .NIF version for a game…its the only program that has the plug-in:-)
Thanks
I just ran off to check out Modo 203. I was wondering if they added that sculpting feature. Guess not.
No sculpting will arrive in Modo 301 release
I just got an email that stated Deep Paint and Deep Uv has been Updated!
The surprise was that the updates are free. A bigger surprise is that they gave my Deep UV. I did not have this before, but I got it now!
@Pilou, Master of links, eternal demo-moder
Think I’ll name that thingie “The PILOU” (if you don’t mind).
It is a lap-steel, and it will be built of carbon fibers and just a bit of wood for the fretboard. And, it will just sing!!
Norhing but MOI “only”, and this had been pure fun.
Zaphod, build it slightly larger and it seems you could have a lot of fun playing in the snow as well!
Lemo
I knew there had been a reason to leave out the wings!!
Just have a look at these http://www.harmosmusic.com/ for some real
fun!
Musical indeed!
