Orient gadgets
Hi :slight_smile:
I’m Edi from evermotion, just wanted to share with you with some of our latest orient models, hope you like it :).
The collection is still a WIP but those models are done of course.
Here is a link to turn around animation of the models…all renders done in Vray.
http://www.evermotion.org:8080/EDi/Orient_gadgets.zip
These all look really well done.
beautiful work, I especially like the bell a lot. can you post some larger detail pix? :slight_smile:
simply beautiful :bulb: greate job :+1: :+1: :smiley:
cool works !
Thanks for comments.
g.g. here is a larger render
wow, those props are fantastic. And i’d love to get my hands on that shader/material- is it going to be included with the DVD when it’s released?
very cool Edi! I like the cut glass red and white vase :slight_smile:
Ofcourse :slight_smile: all models will be prepared to use with Vray, mentalray Fryrender and maxwell. The zbrush models probably will also be on the dvd.
Man these oriental models are exquisite. Have you or do you
ever plan on ever having them printed in 3D?
Nice diversity to your work too :slight_smile:
Thanks EricArtman, hmm no I do not plan to print them. Btw as far as I know its not so cheep to have something printed in 3d :confused:
WOW AMAZING WORK!!! GREAT RENDERS AND VERY NICE MODELING!!!
5 STARS FOR SURE!
:+1: :+1: :+1: :+1: :+1:
Beautiful works there Edi_evermotion. Very good renders.
I was interested to know which parts where done in zbrush? Just interested in your workflow thats all.
first sory for the late replay …xmes fiber etc :smiley:
The worlflow is 3dsmx<<>>zbrush, The base mesh is done in 3dsmax, then I usually jump to zbrush, do some reshape(still in low poly ) then again 3dsmax, some wire correction mapping…at the end ofcourse zbrush and sculpting.
In the case of the vases, before sculpting I’m preparing a coplete ornaments mask. I use the mask to make the base contour of the sculpting, the rest is done by hand. It’s really very easy after the mask is done.
