I am wondering if someone can help me. Biased off old zbrush documentation that was found on line over a year ago. In that documentation there was a way to set up Image Planes.
The process was.
Create your images in Photoshop.
In Zbrush make sure that you have a ztool loaded and in edit mode.
Go to the macro palette
Open the macros sub-palette and then open the rapidstart sup-palette
Press the imagePlaneX button
Load the image plane you saved from above.
Press transform: transparency to turn on transparency.
What ever happened to the rapid start mode in Zbruh 3.1
I like using the image planes this way. I have tried the zplugins for image planes but have found that they don’t work well for me. Is this old way still possible. I would appreciate the help.
Brian
