Odd, I got this double surface thing happening not sure how/why…any thoughts/helps…
Your model may be partly masked. Try pressing Tool>Masking>Clear. If that doesn’t change anything, then select the Flat Color material and turn on Draw>M. After that, press Color>Fill Object. This will remove any material that has been polypainted onto the model.
Ok, Aurick I’ll give it a try
