I’m not sure if anyone else has run into this one yet.
When I export an obj from 3.5 to bake in Xnormal, it ends up freezing xnormal indefinitely. If I import the same hi poly .Obj into 3.1 and then export it from 3.1 as an .Obj again and then bring it into Xnormal to bake, it works fine.
I know this post isn’t directly related to zb. But, the obj exporter should be a universal format and work the same as in 3.1 right?
