OBJ export (answered)
Hi all. I am new to ZB. I have exported an object from ZB as an obj file to open in Lightwave. The object exports ok and it also exports a .mtl file. When I open in Lightwave however, Lightwave is asking for the same file name, but with the extension .bmp. See attached
Any advise to get ZB to include the .bmp file?
Thanks [attach=220300]Screen shot 2010-10-08 at 8-Oct-10 3.40.35 PM.jpg[/attach]
its looking for your texture, in zbrush go to the texture map pallette in the tools dropdown and select clone texture, this’ll send the texture to the texture menu, from there export it, the default is a .PSD file so just change the file format to .BMP and export it and there you go
Thanks. To bad ZB could export in one hot.
What version of ZBrush are you using? I find that a bmp is exported automatically when I have a texture applied to the model.
I am using version 4.
