Nudging in spotlight
Trying the new spotlight it crashes my Zbrush when I nudge an image. It does this every time I try this feature. Spotlight works fine in 4.0 nudging or doing anything al all.
Anyone with the same experience?
Machine:
Win 7.0 ultimate 64 Bit. Intel I7 930 2.8, 16 Gb memory
Asus EAH 5830 - drivers 28-07-2011
Ad
I just tested this on my win xp 32 bit 3 gig ram on an xps m1730 dell laptop. and it didn’t crash when I used nudge. Maybe its a preference setting that needs tweaking?
I’ve got the same issue, each time I use the nudge tool in spotlight it crash zbrush.
System : Win 7 64bit pro 8Gb memory
Solved : I’ve found a way to make it work. You have to load a model and put it in edit mode before using the nudge tool on a texture in spotlight. If there’s no object in the background it crashes. There is no point to use the nudge tool without a model but I did that to try it.
