working on this model off and on. I appreciate any all critiques and suggestions (the more specific the better). Thanks a lot.
-AK
-AK
Ok critique: It needs to be blended together a bit, you’ve got all the muscles there really nicely but you have to remember that they’re covered with skin and that gives you less sharp transitions between muscles. Also his head is too small on top, now he has a very small brain The clavices are way too pronounced as is the neck. But it’s all there so just keep going and working it together and you should be fine. Post some other views next time. Sorry if I’m not clear, but I’ve been working for 12 hours and my head’s not clear anymore
I’ll take another look tomorrow and see if I have more to say.
Cheers, M
http://www.zbrushcentral.com/zbc/showthread.php?t=63377&page=2
thanks a lot Maxim_fleury, that helps. I’ll keep working on it.
Looking good, the muscle structure is great, the only suggestion i have is that the external oblique doesn’t look quite right and the line inguinal ligament (can’t see it all, so I might be wrong here) is a bit off.
Agree with Maxim as well, but getting all of the muscle forms right and then fleshing in the fat and skin will give you a much more realistic finished product.
Great work!
hello there just a few bits to point out. you have too many abb muscles. You have 8. there should only be 6 the muscles at the top under the pecks are classed as Abb muscles. all so you need to brake the muscles up because you can see that you have used the symetry tool. Can I ask what Refeances images you used.
keep going with it
