Ntsc
It seems like there should be a drop down with some standard presets in either the Movie Modifiers menu or in Turntable Plus. Standard paper sizes, standard canvas sizes, and also standard video sizes.
Even if I want to set it up manually, how does one export a D1 NTSC Widescreen video if you don’t have access to the pixel aspect ratio (should be 1.2) and you can’t increase your capture frame rate beyond 20fps (should be 29.97)?
This is what people need to make dailies, prints, and demo reels, guys; it’s important. It’s not impossible to get by without, but I’m used to seeing this in just about everything else when it comes time to set up image size.
i think i’ve seen at least two plugin/zscripts that address these things. i’d check the zscripting forum myself but i’ve gotta go, but they are out there.
EDIT: i reread your post and i think i misunderstood at first. so i’m not actually sure anymore. sorry. if i find them though i’ll post links
I don’t believe any of them change the pixel aspect ratio, including BCast. Not the end of the world. BCast is actually pretty cool. Thanks to lemonnado for making it.
http://www.zbrushcentral.com/zbc/showthread.php?t=42565&highlight=ntsc
