Novice Question >.<
Greetings,
I am a student of animation in the UK and am currently branching out to Zbrush after using 3Ds max as my main means of modeling.
I have been using Zbrush for a good 3-4 months now and have just run into a new problem. For some reason unknown to myself while creating a base mesh with Zspheres I pressed X to mirror on the x-axis but the mirror that is created is no identical to the other. Is there something I clicked that I shoudln’t have.
Thanks in advance.
was the zsphere facing the right way? if you hit X and you see two green circles on opposite sides then you have it facing the right way. Just use the rotate tool on the right tool bar, and not the one on top with edit move and scale. or simply click and hold in the gray area of your viewport, and rotate the zsphere till you see opposite green circles when you hit X.
