Not loading file
Hey All,
Im currently working on a brick texture at the moment, and when I tried to open up the file I got an error message saying “Error has been encountered while trying to load a Tool. Loading has been aborted.”. My file is size is close to 2gb. If anyone knows how to fix this problem would be awesome.
2gb for a brick seems a bit on the high side. That may be the problem.
It is 200 something bricks and I have tried opening previous saves which is under 2gb and still doesn’t seem to work.
If you have save undo history enabled, you may be able to skip loading of it and manage to open the file. 2 GB is asking for problems(if you ask me).
Hmm ill try that thanks, not sure why its 2gb I only have 5.6mill total. And I have made models which have way more polys and half the file size
