Not fullscreen
Hello, just started using ZBrush 4. Quite a dense program but there seems to be a lot of tutorials which is great. My main issue so far is that the program always seems to take the full screen and I can’t find how to make it a floating window. It’s not really necessary to fill a 30" monitor and plus if you want to watch tutorials side-by-side you can’t. It’s either/or.
Can the main window be made to float? Thanks. -Derryl
MacPro (intel). 16GBs RAM. MacOS 10.7
Use the bottom right corner to drag and resize the window. It’s a little tricky but I’ve found it only resizes from the that corner.
