Normal Map in Renderman RAT.
Hi everybody ! :slight_smile:
it’s my first post here ! I was wondering if Renderman Artist tool & other main renderman compliant like Pixie … Can render correctly a Photoreal Girl create with low poly in maya and with a ZBrush Normal Map for details ?
I only find Renderman For Maya answer, with the search engine ! Does it’s gran brother can do it too ?
Thanks for answer :wink:
Easily. :wink:
Thanks for your answer Jason :+1:
I ask this question , because some of my friends said that Maya 7 & Mental Ray have some problems to render zBrush Normal Map ! So with RAT & Main Compliant everithing is ok !
Good to Know ! :wink:
Do you know any Tutorials that will learn me the basic settings to use ! and the comon zbrush to Renderman mistake ?
Best regards
S.K
Well I don’t use Renderman much anymore. I do use Pixie and export from Maya with Liquid, but I handle pipelines. Specifically you need a shader that handles this either way. Easy to implement as many thousands of Renderman API compliant shaders exist, alot with the name Larry Gritz. :smiley:
I can also recomend 3Delight as I was an early supporter. Air, Aqsis, and quite a few others do tremendous jobs.
The Normalmap code must be rolled into the surface shader, don’t try to put it with a displacement shader, very messy. If you find the base shader you want to use, and a shader that handles normalmaps, I can help you get it together and compiled. This is not hard by the way and a lot of tuts exist.
http://www.fundza.com/rman_shaders/ray/basic_ray_tracing/basic1.html
http://gustavobraga.com/english/?p=24
http://mntlrib.sourceforge.net/
A search at http://www.deathfall.com would yeild immense data.
As well as http://www.highend3d.com
and the Renderman Repository - kept together by Tal Lancaster.
It just goes on and on…
:wink:
You’re THE man Jason :wink:
Thanks a lot !
and i agree pixie , aqsis , 3Delight are great compliant !
You might wan to attach this to a shader of chice, say matte or plastic and give it a whirl. It’s not perfect but it works. :wink: You’ll quickly want to modify it with other techniques on the web to be efficient and fast. :wink:
I pulled this out of some old stuff that was cobbled together from various things a couple years back. It’s been reworked quite a bit, but again it’s just a starting point.
Thanks a lot For your great support ! :+1:
