Normal Map from Inserted Mesh
Hi
I subdivide a cube and then add deformations including Inserted meshes from the IM_Curve brush. Then I append a low poly cube, select it and start to subdiving/project all loop. The deformations I did with the Standard Brush show up on the target mesh buuut the IM_Curve inserted meshes do not. Any tips ?
I am eventually creating a normal map for the mesh.
