Noob question, the edit will not highlite!
Once I take off the edit button I can’t seem to be able to activate it again?
Please help!
When you turn off the edit mode, it will drop the model into the canvas.
But no big deal, all you have to do is select your model in tool, and create a new one.
ZBrush will keep everything you have done up to that point, unless you turned ZBrush off, which everything you`ve done since you last saved will be gone.
If you want to save your models as 3D so that they can be sculpted or used later, use Tool>Save As.
If you just want to save the pixols on the canvas (you’re painting a scene or something) use Document>Save As.
Be sure to watch the tutorial movies and read the online documentation in my signature. :slight_smile:
To be honest I have watched many tuts, just a lot of stuff to take in. I have especially been having problems with Go ZBrush. I find that it does weird things when trying to make displacement maps. Sometimes it calls old displacement maps instead of making new ones, its hard to explain.
If I did a video capture of how I do the process could you help?
I am also a noob so most likely its my mistake, lol
another question, when ever I start zbrush I automatically get this default sphere, even when I use go Zbrush I have erase the sphere and then call the object back from cinema 4d to get my object to show. Is there a way to tweak this workflow?
I`ve never heard of that before, which version are you using?
The new version for mac with the go zbrush feature 3.2b I believe
What are the exact steps that you’re following? Please provide simple instructions that will allow us to duplicate your results. Be sure to also include the version number of C4D that you’re using.
Hey there,
I am using C4D r11.
The first issue…I will have to get some time to put that together for you.
Secondly…
In c4d I have my object on the stage, I select it and hit the goz button.
At that point zBrush opens and the default sphere appear instead of the object that is supposed to show from C4D.
So at that point I have to erase the sphere, go back to C4D and push the button again, at that point my object appears in C4D
Thanks again!
