Noob question - Opening and closing projects
So when I make a new project, with an object or two and edit it a bit, its fine i can get my xyz plane and go at it…but once I save it and open it back up it seems stuck in the middle of the screen and i can edit it or anything…what do you have to do? i’m used to 3ds max where you save where you’re at and it comes up exactly as it was when you open it back up.
Go to the File palette and click on the Save As button
http://www.pixologic.com/docs/index.php/ZBrush_Projects
If you save just the document the 3D objects are no longer 3D geometry but is, instead, Pixols (2,5D).
http://www.pixologic.com/docs/index.php/Document
