NooB needs help...
hey guys… first post and thanks to anyone who reads or comments. I’m currently making my first more “serious” model in zBrush and I need a little help.
Here it is…
Anyway any suggestions would really, really help. Thanks for reading!!
P.s. I know the model isn’t exactly HD especially on the head but its all my machine can handle!
Sometimes an alpha just won’t do it. What you can do is to use the Damien Standard Brush (use lightbox to find it or load it from your brush palette. It’s located under …/osProgtamPath/Pixologic/brushes) or something like that… Then you could actually sculpt the scales individually. With that reference you should be able to read all the shapes. Remember to set the smooth value on DamStandard to 0 under brush-modifiers.
Here’s an alpha that might help you out a bit. You can try DragRect stroke or Stencil or even Spotlight, but DragRect stroke with Z Intensity at about 10 will probably do the trick.
