Sorry if this question has been answered. “Search field” and “Google” did not help
How does one manually set a path for Goz if your app is on a drive other than “C:” ???
Any help greatly appreciated !!!
Before you can do anything you need to install the GoZ components. What is needed for GoZ to work with Poser comes from Smith Micro rather than from Pixologic because they’re the ones that created the GoZ implementation for their app. You should find instructions on their website or documentation, or be able to get it from their support.
After you’ve installed what’s necessary, you should be able to simply run GoZ and let it search for GoZ-enabled applications. At that point GoZ will know that Poser is such an app and it should appear in the list when you search.
You have to edit the Goz_config file. Mine is in this location (along with three other files): C:\Users\Public\Pixologic\GoZApps\Poser
The file should have this single line (your path will be different): PATH = “C:/Program Files/Smith Micro/Poser 11/Poser.exe”
Make sure the path is where you installed Poser on whatever drive you have chosen.
