Noisemaker using an alpha question.
When I import an alpha to use for a pattern with the noisemaker edit window open I seem to be able to manipulate the scale and strength with the sliders at the top right of the window and the focal shift slider and offset just below the focal shift curve mini window on the right hand side of the noise edit window.
But all of the sliders below those don’t seem to do anything. Those would be the 3 each for the X, Y & Z offset, angle and scale.
I went and reviewed the video tutorial on using the alpha feature of noise maker but they only use the scale and strength at the top right and never make an attempt at using those lower sliders.
Has anyone else experienced this problem or I’m I just doing something wrong or missing some step?
Just bumping this one and hoping someone can shed some light on this.
Hi EZRA,
Those sliders are for the NoisePlug plugin. I think the only way you will be able to control an alpha is with the upper right sliders and your UV’s.
Thanks Zber. I appreciate the response. Too bad though that you don’t have a bit more control of the noise from an alpha pattern. Oh well, maybe next upgrade.
