About NM: is the NM result automatically transferred to the model’s normal map? Additional question: is the return key in the post inputing box disabled?
no. you have to apply your noisemaker to the mesh as actual geo. It is only displayed as a bump map.
Hi Beta. Can you tell me please how to do this? Thanks.
Tool: Surface: Apply to Mesh
Be sure to make sure your mesh has enough vertices to support the detail from the surface noise.
Ok, done. Thanks.
er… sometimes when I export a model as obj from modo, I don’t get the uv option in the noise generator! what’s up?
