I’m trying to add color noise to a layer in a ztool. When I click on Surface noise, set the strength to 0, and adjust the settings so that I only have noise applied to the color of the model it all looks fine. But when I apply the noise to the mesh it simply does nothing. If I get rid of the layer and then try, the noise works OK. Is it possible to apply color noise to a layer?
Steps to reproduce
- create a polyshpherer, sculpt, subdivide to ~1mill polys, add poly paint.
- create a layer on ztool
- activate noise, adjust as desired, set strength to 0, and turn on color blend.
- hit OK, you can see color noise.
- hit Apply to Mesh, and it fails
If you adjust hte strength, then the deformation will come through, but all the color blend info is lost, no color noise is applied.
I’m on Win7 64 bit, Zbrush 4R5
