Noise Maker Question
Hey guyzzzz! I want to design my own noise in photoshop for Noisemaker in Zbrush, I know there is by default 12 Noise effects in Zbrush, how do I make more (turn the files I make in Photoshop to Znm Format?) Thanks in advance!! -Jonny
Would like to know as well:)
You could create the noise like a heightmap, and save it as a .psd file. In Noise Maker, towards the bottom left of the preview window, there is a button to select and use an Alpha Map. If you wanted to save the image and settings for quicker access in the future, make any adjustments to the settings that you want, and then click the save button towards the top right of the noise maker window to save everything as a .znm file.
