All of the default noise brushes that come with zbrush no longer work in 4r4 (or 4r3).
I’m guessing what happened is something in the “Brush > Surface > Noise” palate change which caused these brushes to lose their settings and no longer work.
It is odd because you can still edit the “Brush > Surface > Noise” settings and make the noise brush behave correctly and the brush will also still save and load correctly after you have tweaked the noise settings…
Is it possible to get Pixologic to re-save out these original brushes so they work again?
