I’ve been having some serious issues with the move transpose in ZBrush 3.5r3 and the current ‘solution’ isn’t enough. Whenever I try to scale the unmasked selection (click an endpoint on the action line and drag), the entire mesh distorts horribly in a way completely unrelated to what the line dictates.
The ‘solution’ I found in the forums here is to turn off symmetry. That’d be great, but I don’t have time to sit through 5+ minutes of Smart ReSym-ing, which may or may not produce the results I want, for something that could be done - and had been done in previous versions - in less than 10 seconds.
Is there no true solution to fix this?
Here’s pics of the problem itself, taken in ZBrush 3.5r3.
Move transpose before:
