hi i have a problem pl helpme
when i run the Z-Maper
zbrush gives the runtime error
it tels NO GL_EXT_texture_env_dot3 support
pleas help me thanks somuch
Usually caused by one of the following:
You’re running Zbrush in a virtual machine. Usually the OpenGL support is not at a high enough level to support Zmapper. Run Zbrush naively or use native dual-boot solutions like “Boot Camp”.
You’re on a relatively old machine and your graphics adapter doesn’t support a high enough rev of OpenGL.
Your graphic card’s drivers are out of date or damaged. Reinstall latest graphic card drivers.
-K
thanks sir somuch
i try this hope it woek for me
