No 'Fill Object' button to the left?
I want to texture my object. So when I pick a colour on the small colour picking pallette to the the left above ‘Switch colour’ and ‘Alternate’, the whole object becomes that colour (except the wings). Why the wings? I cannot have them another colour. And when I for example mark a toe, the tail turns the same colour.
Another issue is that I do not possess the Fill Object button to the left.
Please help?
Fill Object is located in the color menu…
Many people have it down to the left. How do I get it there? The problem like I said is that when I click a colour it is instantly applied to the whole sculpt (except the wings?). :I
Go to “Preferences > Config” and click “Enable Customize”. While holding down Alt+Ctrl, you can click and drag the “FillObject” button to where you want it. After that, go back to Preferences > Config and disable “Enable Customize” button then click “Store Config” in the same menu.
ZBrush has a live preview of materials and color which will preview on all subtools. To make a color and/or material permanent on a subtool, at the top, you select “Mrgb” (material and color), Rgb (color only) or M (material only) then click “FillObject” on the selected subtool to finalize it.
