Hi all,
I’m hoping someone can answer this as I’m up against it at work at the moment…
Basically I’ve got a sculpt sitting at level 6 and the “delete lower” button is greyed out? (It’s a single mesh with no subtools.) I remember when this used to happen (in version 3) you cloned the tool and it usually fixed it. I’ve tried that in 3.5 R2 and R3 now and have had no luck at all?
I’ve got 6 levels of division on my mesh and 4 levels of HD active? I’m trying to delete higher at level 3 in order to bake a displacement map out to level 3, then delete lower from level 4 and make a normal map out of the higher frequency details and the HD I sculpted.
Any thoughts on a worksround for this problem in these versions of the program?
Thank you
Mike
