No button for 'ShadowBox'!
Hi everyone, I am very new to ZBrush (in fact, I’ve only had it for a few hours), and I need some help with something regarding the Shadowbox Feature…
A little background:
I will mostly be using ZBrush to design jewelry, and I am also using 3Design CAD for a majority of my parts. I am hoping to combine the two and use Illustrator to start my projects. I will mostly be doing hard modeling, I think.
What I really need in ZBrush is the Shadowbox feature, and I have followed the instructions in the documentation tutorial pdf, but I am running into an issue. The tutorial says to load a standard shape and then click the ‘Make Polymesh3D’ button. (that part I can do fine). Next it says to click the ‘Shadowbox’ button in the ‘Subtools’ palette. Well, where the button should be, it is not! Maybe I am doing something wrong, but when there are only 3 steps, I feel as though something else is going on. I am using the 4R3 version, in case that makes a difference.
Any help would be awesome, thanks!
In 4R3, ShadowBox was moved to the Tool>Geometry menu. It makes more sense there than in SubTool.
That was it! Thanks so much for your help.
