Just wanted to create a non-organic piece in ZB, but the symmetry has gotten off during the building of several sub-tools. I have tried “ReSym” but crash. What are the rules of “ReSym”? Or what causes this in the first place?
Thanks
Thanks
Make sure to rotate the model slightly on the canvas after selecting a SubTool, before you use any deformation. There is a known issue in ZBrush 3 that causes a crash if you attempt to use a deformation immediately after selecting a SubTool.
Also, you may get best results by going to level 1, masking one side of the model, then using the Smart ReSym deformation. Then work your way up one level at a time, reapplying the Smart ReSym at each level.
