newbie question: making a belt buckle
I’m starting with a cube, going into ‘initialize’ to set material thickness, then masking out a square inside the center. At that point I create 2 polygroups via masking and select the outer part, hiding the inner section. But when I do a mesh extract I end up with a hollow buckle.
Am I trying to do this the hard way? Step-by-step what is the best way to create a basic solid buckle?
why you dont use the zsphere?
