how can I have all my alpha brushs show up without having to load each on individually each time I open
same with brushs
also how can I save my ui
same with brushs
http://docs.pixologic.com/getting-started/sculpting-a-head/
how can I insert an image like the one shown for reference
is there a way to download all that in pdf, most of that stuff there is not on the getting started pdf
or any other of the ones in the docs folder
guess not
another question i came across is now ive got the rough skull shape in with the grid and reference photos
it seems the move brush is not what i need to use now im trying to get the shape a bit more detailed like the nose and jaw
from the sides trying to use the move brush just pulls a point out instead of the whole side
if anyone can understand what im tryin to ask
Use masking and move topo to work on more points where you want. The standard brush will push vert’s in or out depending on settings used. Hide parts and or zoom in to achieve the detail you want in certain areas. Display the PolyFrame as it can be quite helpful.
can you mask off an area and cut that area away?
