When installing 4R4 yesterday I bypassed the pdf and successfully installed the program.How do I retreive the new pdf document?When in the program I opened my document window and cant find the pdf in the documentation folder.If I lost it in the install process how can I retrive it?Also when downloading the document from the online site and reopening it on my computer I got a bluescreen.
Thanx in advance.
you may want to update to 4R4 2P…
http://www.zbrushcentral.com/showthread.php?170337-ZBrush-4R4-Update-2-is-Ready
Done that already…I did upload the 4R4 2 without success
The PDF documentation is installed in the ZBrush 4R4/Documentation folder. Launch Acrobat Reader and navigate to the documents through the Open dialogue.
If you’re having trouble updating to 4R4 Patch 2 then you should take out a ticket at the Support Center.
The online documentation is essentially the same as the PDFs.
Thanx Marcus for your response…I did upload the patch successfully…I’m talking about the pdf. Even if I navigate from my acrobat I still cant find the pdf file.Also for some reason when downloading from either a “save” or “run” I get a computer crash or blue screen.This might be an unrelated issue.If anything I’ll just go online to read it.Thanx again for everyones help
David
W6DLB
I found the pdf file like you suggested by opening up acrobat first.I thought you could open up the docs from inside zbrush.when opening a document in zbrush you are only limited to zbr. files thats why it was an empty.Also this pdf is a “secured pdf.” so it doesnt have a save function.Also when searching for the document I had to change the file search to “all files” to find it.Because the default file search is automatically “pdf.”.and it could’nt find the document even though it was searching “pdf”.I really hope I confused everybody now lol.Seriously I’m just an old fart whos already lost half my mind and sorry you have to put up with these fundamental issues.I think this is a great group of people here.
Why didn’t you just go to the ZBrush 4R4/Documentation folder and double click on the PDF file? I don’t understand why you are going about it the way you are. Your computer knows that a PDF file belongs to Acrobat.
Like I said the folder is empty when I go to “4R4 Document folder”.Ive never had trouble before collecting any documentation up till now… for some reason.But I’m good to go now even though I had to take the long way around so to speak. But thanx again for your speedy responses.
David
W6DLB
