new materials problems
hi all.
I have a problem with new materials that overwrite old .
when I add new materials in the zsturtup/materials directory some of them overwrite preloaded materials, so when I go in the material’s palette I find the right name of the material I need, but with different properties and characteristics and the issue that I can not modify them through the materials modifier panel. every modification that I do to different parameters doesn’t affect the result.
the only way to use all the materials is to put new materials in the zmaterials directory, but when I select one of them it reload the active material in its slot and I have to do so each time I need a different material.
is there a solution to this issue?
thanks in advance!
