need some help
im trying to make a self portrait and im fallowing a tutorial but when i click the texture i want its not actually show up on the image plane someone please help
If you are using zbrush 3.5 they have changed the way you apply textures to models from the way that zbrush 3.1 used.
In zbrush 3.5 you load the texture like you normally would from the texture menu on the left. Then select the tool/sub-tool that you want to apply the texture to and under the Tool menu on the right (using default interface) scroll down to the texture tab and open it up.
Now make sure that the button Texture On is checked. Click on the image box and select the texture you want to apply to the model. That should do it. Good luck!
thank you very much
